Hello,
A few general plumbing questions for you pro's:
Can 15mm copper pipe be run through stud walls length ways? ie drill 16mm holes through the center of 3x2" studs?
Do pipe joints & waste pipes need to be accessible? Or boarded over ok?
Are position of runs an issue ie height wise, distance from corners of adjacent walls etc or are there safe zones like for electrics?
Can 15mm copper be run down a wall chased in to supply rads? Same question, position of runs & is any mechanical protection needed?
Also would the pipes need draincocks at bottom of pipes?
What are the recommended spacing of fixings?
I looked in the Wiki but the link for "pipes-joists" is empty, could anyone point me in the direction of building regs for this info?
I need to get it right as its got to be inspected by Building Control. Its an extention, thermalite block inside, just a bare shell at moment, but I really need info on how to do first fix before I notch, chase & drill everything in sight! I plan to use 15mm copper pipe, soldered end feed joints.
