Sanding belts - recommended brand?
23 Mar 2007
Cheshire
I was wondering whether it is worth paying a premium for sanding belts from manufacturers such as Bosch or Festool - have you experimented? Do more expensive belts last longer? Can anyone recommend a manufacturer with the optimal compromise between quality and cost?
Have Bosch belt sanders and only bosch belts seem to fit so don't have a choice.
In my experience, you can feel the join in the cheaper non-branded belts when you're sanding - which tends to make the belt sander 'jump' a bit. I haven't had this problem with the bosch belts i've used in the past.
ive always used makita belts been ok, i have a makita sander
if you can get festool belt to fit yours its well worth a try, i have a festool ros and the paper is good quality, lasts ages
Try Screwfix for sanding belts of various sizes. Good quality and affordable - they sell to the trade, so would soon get to know if anything wasn't up to snuff.
Axminster Power tools also good.
You must get the right size - check youir owner's manual
norton (or other) blue zirconium - sharpness lasts longer, pretty much essential for hardwoods if you value your time.
you can get them a lot cheaper than screwfix. eg bnd abrasives.
otherwise no name red aluminium oxide, not convinced that bosch etc; offer any more wear for the money.
