Hi I was i the shower this morning and suddenly the water was scalding, it turns out my son had turned on the cold water in the bathroom. Is there something wrong when it can scald someone in the shower is there not a safety issue here ?
If needed then just install an adjustable TMV then set that to max, some will have a 60deg max setting, though most have 55deg @ 30-40l/min @ the systems nominal dynamic pressure. Not sure how much HW temp/pressure and flow the OP would need above that.I don't think that would work Madrab (well it would sort of), If you control the potential overheat with TMV upstream, then that's the maximum temperature you'd ever get
