Hi all,
After purchasing a house I'm in the process of sorting the loft out and found some wiring I'd like confirming.
From the consumer unit 16A MCB a 2.5mm2 cable runs upto the loft and directly to a Pull switch in the bathroom. From the Pull switch, another 2.5mm2 cable runs to a FCU. This is fitted with a 3a fuse.
From the FCU out a 1.5mm2 cable runs to an extractor fan. Also a 0.75mm2 flex to the shower pump.
The consumer unit is a Wylex Dual RCD unit.
Thoughts ?
Thoughts ?
