Hi Guys
I recently fitted a low profile shower tray. Its plastic, which i've always steered clear of but because it was low profile, 40mm, I figured that it shouldn't flex. It was bedded on s&c 5:1, tapped down, levelled and left to set. All fine so far. However I tested it to check the hi-flo waste etc and after 5 mins of running it lifted at the front quadrant edge. its now out and there are no obvious reasons as to why it's gone this way. The render has set and there are no low/high spots. For some reason there does appear to be some condensation? It appears as if the hot water has flexed the tray and broke the seal (which would explain the condense) but am I wrong in expecting a shower tray to withstand a bit of hot water!!!
I have fitted dozens of trays but never a low profile. The reason for my query is that tbh i'm a bit stumped. Its confirmed my hatred of plastic but i need to ask if theres anything obvious ive missed before i consign it to the skip and get a resin tray, bearing in mind the floor and waste is all set and i really dont want to have to 'start again'. I really dont have the heart to have another go, it should have been perfect. Can anyone offer any advice? Anyone experience the same problem?
Cheers Guys
Cheers Guys
