Siemens REV17 replace with REV24RF?
30 Dec 2013
Dorset
Hi experts, can I do a straightforward swap of a REV17 with the wireless REV24?
By straightforward I mean the wall plate may need changing but the existing wiring will be ok.
Thanks, Simon
Probably not as straitforward as you think! From what you describe, you want to exchange a wired programmable stat with a wireless one.
What type of system do you have?
Combi or conventional?
Eithere way it requires some rewiring to the rf reciever
No, as one is wireless the wiring is substantially different.
This is for a conventional system. The heating thermostat is in the hall and was previously one of those traditional rotary ones, it was replaced a couple of years ago, when a new boiler was installed, with the Siemens. I want to put the receiver (the bit without the display) in the hall replacing the Siemens and have the control unit in the lounge.
I was assuming that as the only change was that the 2 boxes needed to talk to each other and the receiver would just use the existing wiring.
I take it I'm wrong?
Simon
The wireless one needs an additional permanent live and neutral. Not a straightforward swap.
So wouls it be better to replace the programmer next to the boiler as I assume that is mains powered and do away with the thermostat in the hall? The thermostat next to the boiler controls the hot water and has the heating on constant as the REV17 in the hall was controlling that. I assume the REV24 can replace both.
Simon
The REV24 is just a room stat and your system would be better with a programmer and room stat (or programmable room stat). Not a good idea to put a room stat next to the boiler either.
