I have a brick shed where the front and back walls run the entire length of the terrace. The walls that then divide it up into individual sheds are not connected into the front and back wall. Therefore there are gaps in all four corners. i wish to convert this for office space and therefore need to seal, insulate and plaster the building.
I have thought about putting bolts into the walls near the corners and then casting a concrete pillar around them, to fill the gap and tie the walls together.
Any other thoughts or detailing for this (i.e. which bolts to use and how to attach them to the brick) would be extremely useful.
Also any suggestions for how to damp proof and insulate the floor which is currently a concrete slab.
Thanks in advance
Thanks in advance
