we are planning a 2 storey extension on the side of our semi-detached cottage which was built around 1900.
The external side wall is currently 'single skin' 4.5inch thick brick on both floors, rendered, and insulated in the inside. The wall measures about 5m x 4.2m high to the guttering level of the roof.
Once the extension is built (using a cavity wall) this single skin wall will become and internal wall.
We know we are likely going to have to strengthen the single skin wall, and a builder has suggested building a second skin outside of the existing wall and securing the two using wall ties. He said this would have to be the full height of the existing wall, with a foundation dug for the second skin of 1m.
Is it correct that now that the wall would be internal it needs such extensive strengthening? Would it be possible to strengthen the ground floor wall and not the first floor or is this pointless?
Does anyone have any alternative methods which we could discuss with an engineer which may be easier to achieve, such as using steel to increase strength/support?
We just want to make sure the house is mortgageable when we come to sell it. We are prepared to pay for the second skin method, but don't want to commit to such an expense before investigating alternatives!!
Thanks in advance for any guidance.
