I have a concrete floor slab in the hallway of my home, which has sunk about 10mm from the floors of the surrounding rooms.
The house was built in 1968. The slab hasn't moved in the three years I've owned the place.
I have been searching on ways to fix it and found a process called slabjacking which involves injecting PU foam into the void under the slab in order to raise it. It seems like a quick and relatively clean way of solving the problem, vs re-screeding the floor. The floor covering is parquet, which I would like to avoid disturbing if possible.
There appear to be lots of companies offering this service in the US, but I can't find anything in the south of the UK. Does anyone know of any companies in the UK that can do this work? Alternatively, does anyone know if it is possible to rent the equipment to DIY?
