hi
strange problem with 105e.fixed hundreds of these boilers n never had this one hope someone can help.
boiler sits fine in standby but when you request either dhw or heating pumps cycles off and on 5 or 6 times then fan starts and fires but the indicator light for dhw or heating does not come on till pump has tried say 6 or 7 times.pumps runs for 2 seconds at a time have checked both flow switches and wiring and they make straight away all thermistors in range tried second hand pcb n it does exactly the same and it does the same cycle every time boiler gets to temp or is shut down and restarted.
have tried all the usual process of diagnostics and nothing i find it strange there is no demand light straight away and fan wont run till pump has cycled even though the flow switch has made and the voltage is there.
and is definitely the right pcb!! any suggestions anybody regards david
