I have a project where I need to build a simple wooden frame to support a static load of no more than about 150kg. I'm not great at woodworking so I plan to just bolt lengths together to make the structure. I am trying to avoid over-engineering it (as I tend to do) but am starting to doubt my design. I am using C16 45mm x 95mm timbers and plan to make the joints using a single M10 carriage bolt with a double-sided connector plate between the pieces. There will be 6 'legs' to the structure, so assuming the structure speads the load reasonably, the maximum force on each joint should be no more than about 30N (allowing for the weight of the structure itself)?
Surely I am worrying needlessly? The OCD part of my brain is telling me to use 2 bolts to be safe and I am trying to resist! What sort of load can such a joint really hold?
