My first post - probably obvious to you guys, but I'm looked for a few hours and can't find an answer.
I'm planning to replace the all the ceilings, floors and stud walls in my house becasue I'm changing the layout. (there are no internal structural walls - all the joists are supported by RSJs fixed to the external walls)
The previous owner put chipboard flooring and plasterboard ceiling to the entire upstairs BEFORE they fitting the stud walls. As a result some of the walls are only supported by the chipboard floor with no joists under any part of the wall. (specifically 3 walls (3.5m long by 2.3m high) are only supported by chipboard that's in pretty bad condidtion)
When i replace them, my intention is to fit the stud wall frame before the ceiling/floor, putting short cross joists in where needed to support the walls. And then to fit chipboard floor / plasterboard ceiling to each room separatly.
Am I right to do this? or is there a good reason to do it the way the last owner did?
Thanks in advance. (and apologies if I got any of the terminolgy wrong)
Excellant site by the way - think I'm going to save £5,000-£7,000 from my refurnishment cost from reading all the posts this weekend.
