If anyone has come across this problem and found a solution, I would appreciate your advice.
I recently had a Mira Realm Thermostatic shower fitted and although it gives a good forceful flow at a comfortable temperature to begin with, the temperature fluctuates all the time; it switches from hot to cold about every minute - which is maddening. It's ok now because it's summer but in the winter it's not going to be fun at all!
The shower is installed on a Glow worm Betacom 24c boiler system.
I have tried the shower with the flow adjuster fitted, and without, following a conversation with MIRA, but the problem is the same.
I have tried with the water output temperature of the boiler set on high, and low, but this doesn't appear to have any affect either.
I did ask, when I bought the shower, if it was OK for combi systems, and I was told it was.
Now, I wish I had bought an ordinary manual mixer shower but it's expensive to just chuck it away and get another one.
Any suggestions? [/b]
