I have recently installed a thermostatic shower mixer that replaced an older one. I installed it without reading the instructions because I've fit many showers before and besides this was a like for like swap.
The shower exhibits behavior the likes of which I have only seen once before on a shower I didn't fit and therefore didn't have to solve the problem.
When the flow valve is opened, no water flows. If the basin hot water tao is then opened sill no flow. But finally when the basin hot water tap is closed the shower flow begins.
The instructions state that the shower should be fitted with its own 22mm supply directly from the cylinder and that it should be fitted using a essex or sussex flange and should have no branches supplying any other fixture. Neither of these instructions have been followed.
The hot water tends to be too hot and I believe that most of the time, if not all, there is no cold water flowing through the mixer.
The run from HW tank to shower is long and would involve making a mess of the house which I would like to avoid. Can anyone explain this phenomenon?
My thoughts are:
1. The cold water pressure is not enough to allow thermo valve to open when in presence of higher hot water pressure. Opening the basin HW tap reduces the hot water pressure to the shower but by too much to allow it to flow up through shower head. when closed again pressure is enough to flow through head.
2 Some sort of air lock... Someone mentioned dead legs? Could anyone explain the physics involved here.
Please help
My thoughts are:
Please help
