Hi all.
We have had an extension built on the side/back of out house - classic early 20th century terrace. On the rear we have bifold doors and asked for a single panel window above it. This is right-angled triangular with long side at the lower edge, about 2.5 M along and just over a 0.5m straight up. When they have fitted it it looks like they have added two vertical bars so it looks like its three pieces of glass (incidentally these bars almost, but not quite, match the hinges on the doors below so doesn't look bad as such, - however its not what we asked for). My builder was unclear whether they have done it as three panels or one big one with the bars 'added for strength'. He also says that they have probably used 'ordinary glass' rather than 'strengthened' glass they will have used for the doors and a much larger floor to ceiling window in the side wall.
When we queried this our builder says the vertical bars are for strength and that the window company will not guarrantee the window without them, for example if a bird flies into it it is likely t crack. If thats the case then I can see the reasoning, although it would have been nice to know this when we ordered it rather than after the fitting.
So, is there a limit to the size/shape of a window we can use without using strengthened glass - and what are the limitations? And if we go for strengthened glass, what the proportional cost increase likely to be?
Pete
Pete
