It works, but when you turn a tap on the temperature drops right down to 28º before it starts to light. The HW Flow led comes on immediately.
So if the CH had been, on you get a warm bit, a long cold slug then it starts to heat up as normal.
Similar on CH. Fan comes on, pump runs, temp drops way down, then the boiler fires.
Old DV so I replaced it having first seen a HW problem and not the CH version - made no difference. Also tried new HW ntc - no difference.
Vaillant think it must be a pcb problem.
