Can anyone offer some advice as to whether this is supposed to happen? Or why it is happening?
We have just had 3 new showers fitted, along with a new heating/hot water system.
We have an Oso water cylinder at 2 bar. Mains pressure is 5 bar with 30l/min flow (tested by waterboard). Also a new mains supply pipe and stoptap.
Some of the showers arent as good as we expected them to be. I have measured the flow rates at the shower head (time to fill the bucket etc) and have found the following:
First shower gives 15 l/min flow with cold turned on, and 15 l/min with hold and hot turned on (this shower give a nice shower)
The second (same make as first) has 15 l/min with just cold water, but 9 with cold and hot water. Surely the flow should be the same as its a balanced system?
The other gives 10 l/min with cold only, or hot and cold. This is supposedly a better make, and according to the manufacturer, we should get 18l/min at the shower head with the pressure/flow on our system.
Kitchen sink gives 10l/min via 15mm pipe
As far as I know, all pipes are 22mm for most of the runs.
Does the system need flushing or something, or do we have faulty shower mixers, or balancign valve or something like that?
