Hi
I have been working on a vaillant 282 and have replaced the dhw heat exchanger. This has improved the hot water temperature but I still think the water section needs replacing as the temperature setting wheel does not adjust water temperature.
I replaced this part about 2 years ago with a reconditioned part. Having looked inside it before I am not clear as to how the unit varies the output temperature of the hot water. Can someone explain this part of the device, I can see how the diaphragm works to switch the boiler on when demand is made but how does it reduce flow rate to control temperature?
Also the control wheel seems to,break very easily when the unit starts to get stiff with age, is there a fix for this? Buying a new valve every time is very expensive as the wheel is not sold as a separate part far as I can see.
Thanks for any info
Stu
Thanks for any info
Stu
