Vaillant Boiler Hot water fault
21 Aug 2013
Shropshire
Hi can anyone help me? My hot water is luke warm then tepid luke warm then tepid continously. Even though the temp gauge is showing 80d? My boiler is a Vaillant Turbomax VUW GB 242/1 E. Any help to sort this would be much appreciated, thanks
Simple way - throw it in the bin and buy a new one
Occasionally effective way - take it outside and blast it through with a hosepipe
Professional way - connect a powerflushing machine to it. Or throw it in the bin and buy a new one
Is it easy to remove?? Do ineed to turn anything off? Are there detailed instructions anywhere??
thanks!! Can i clen it out myself or do i need a gas safe person? if so i need to replace the o-rings? can i buy thm seperate?
You can do it yourself, replacing the washers is advisable, you should be able to get them from a plumbers merchant or maybe B&Q
