Vaillant VCW GB 242 E
2 Feb 2009
Kent
Has anyone got electronic versions of user and/or servicing manuals for the Vaillant VCW GB 242E combi boiler.
I have hot water but no heating (picked a super time to decide not to deliver any heating with 12 inches of snow on the ground!!) and want to see if there is anything I can do to check it out.
Obviously, I'll supply my e-mail address to anyone who can help.
Gerry
I expect you have checked the programmer and room thermostat are calling for heat, if so the diverter valve is what you need to check to make sure it is changing from hot water to heating.
I saw one a few days ago and it had same problem,I found the return valve shut off :eek:
someone had topped up and shut both valves(screw slotted type) and hence no heating , the poor fellow was overjoyed as i had told him before looking that it might be the end for this old boiler :evil: .
Probably the punger sticking and keeping it in hot water mode
Ah I dunno the little plunger thing that the diverter pin pushes against with the adjuster on the top...it's not called a plunger either but I know what I mean.
Had to get the Vaillant guys in. They changed the fan/motor and it now works. Goodbye £275.
Still interested in the elctronic manuals if anyone has them.
