Washer/drier, filling with water
2 Jan 2007
just to rewrite a previous problem i have with my hotpoint washer drier, after use/overnight it seems to be filling slowly with water, i'm not sure whether its connected but our softner draw used to be water logged now its clear, please help. thankyou
__________________________________
lynda, moderator
please note forum rule 1a, also item g, your other post has now been deleted
clean or dirty water?
Clean water = passing inlet valve. replace inlet valve to cure.
Dirty water = back syphoning. Raise drain hose as high as the underside of the sink before going into spigot. Or, if it's into a standpipe, pull it out and only insert the pipe into the standpipe 2 or 3 inches.
Thankyou for the advise i thought it could be something like the valve as the water is clean, thanks again, matt
Washer drier has 4 valves, a triple cold valve and a single hot valve.
To determine which is leaking, turn off the cold water at the valve (normally under the sink or thereabouts). If it still fills overnight, switch the cold back on and next night switch off the hot. If it still fills, next night switch both off. If it's still filling then it's dirty water and you need to sort out the drainage.
If after all that it still fills, bottle it and sell it as miracle water. :p
