Waste
12 Aug 2018
Hi, just a quick question, I have ripped my bathroom out and need to move my basin, the waste goes from the soil pipe, to the basin to the bath, so it’s in inch and a half to the tee at the basin, then reduced down to inch and a quarter, to cut a long story short I have cut the inch and a half pipe near the soil pipe, I have solvent weld fittings, they fit on the pipe that I cut, would they not fit on the pipe if it was push fit pipe? I just don’t want a leak
Solvent weld fittings would be a very slack fit on push fit pipe ,and snug fit on s/weld pipe.
If it says pp it's push fit, abs or upvc are solvent. Also as above the external diameter for 1.5 inch is 40mm for push fit and 43mm for solvent.
Can you post a pic of what's there/what you've cut out. Should be able to tell from the pic what type you have.
