Help please - We have just spent a fair bit of money having the bathroom in a small flat modernised. One of the principle things we changed was having the old metal bath removed and a walk-in shower installed instead - and it does look much nicer.
However, when we came to test the shower the water simply wouldl not exit fast enough and the shower tray soon fills up and overflows. We looked at the trap supplied with the shower and it has a small cup inside into which fits the water outlet. Thinking this may be the problem we took out the trap to see if the water will exit better and it does to a degree - but not quite fast enough to stop the water level gradually rising in the shower tray.
One thing we noticed is that as the water level drops is that air seems to bubble back through the drain into the shower which I would not have expected. Is there a logical reason for this? It seems to me that this may be casuing the water not to drain away fast enough! but I am no expert so am guessing. The wash basin and the toilet empty perfectly.
Another issue which may be affecting things is that the shower outlet is some four or so inches lower than the one that was in the bath. We have used the same pipe connection for the shower as was used in the bath - so could that be influencing the problem!
Another issue is that being a flat built in the 80s, we cannot see exactly where the outlets actually go to all we have is the places they enter the flat though the concrete floor!
The builder who installed the system seems at a loss as to the cause of the problem - so I am getting another plumber to have a look but would welcome any comments people here may have as well.
As this flat is normally rented for holidays we are desparate to find a solution as we are unable to take tenants at the moment.
