I am having new bathroom fitted and looking at all these fancy showers at the Hudson Reed website, but what will work? I have a Worcester 24i combi boiler, with 23.4kw output. Does this narrow my options? The bar pressure is 1.5. Advice appreciated
DOn't expect more than 8 litres per miinute at showering temp from your boiler. It will vary.
IF your mains is reasonable, pressure shouldn't be an issue, check the flow rates required by the heads of the showers.
