Just wondering if any of you gurus out there could suggest which version of Linux in your opinion is the most efficient with regard to system requirements and also has the most up to date device drivers.
I've been looking at Suse, linspire and redhat. Suse seems to be looking for quite a high spec in comparison to XP home [800MHz compared to 300Mhz], Linspire ive heard is the easiest to make the transition from windows and Redhat seems to be the most configurable.
As you can probably tell I'm haveing a hard time making my mind up and any guidance would be really appreciated.
This will be installed on a 1.6 pentium M, 256Mb DDR,40Gb HDD Fujitsu laptop and I would like to be able to run the OS without listening to the HD grind away while waiting for my apps to load. I realise that the memory may be a bit lacking, but I hope to upgrade in the future. Reason I'm thinking of making the windows to Linux transition----Have you seen the spec required for Vista----pweeeeeeeewww 2Gb memory----now thats bloatware!!!!!!!!
Thank in Advance
pc
Thank in Advance
pc
