Hi All,
I searched for this through the forums - lots of info came up but none seemed to be recent.
I have a whirlpool bath and it needs connecting to the ring main. The ring main passes through the wall of the bathroom - there are a couple of sockets on the outside of the bathroom wall.
Obviously the pump needs connecting through an FCU from the ring and there should be an RCD in the circuit somewhere too. A plumber that recenly visited said the regs had changed to insist for an RCD FCU even if the circuit is already protected by an RCD at the comsumer unit.
My house is only 10 years old and all circuits are protected by RCDs at the CU anyway, so my question is:
1) Do the regs stipulate that the FCU must be an RCD FCU, even if the circuit is already protected by an RCD?
2) I see no harm in using an RCD FCU anyway (just to be on the safe side). In this case is another switch required for "general use". E.g. a pullcord switch to be used for day-to-day on/off switching. This would allow the RCD FCU to be always "on" and we could just use the pullcord in the same way as one would for an electric shower.
I am aware of Part P, etc so I plan to do this work myself and then get the Part P approval certificate from a sparky.
Cheers,
Ben
Cheers,
Ben
