Hi
Ive searched the net for an answer to a problem i have with my worcester bosch 24cdi boiler but to no avail ! Rather then sign up to some random diy forum i thought i might as well try here, and while im at it i can see check out some savings accounts !!
Anyya, although the boiler works (or seems to) there are a few things that dont seem right...firstly, sometimes when running the hot water the water pressure will drop slightly and i think that if it drops out on the boiler too much the boiler stops firing (?). We live in a 1880 terrace house and think that there maybe a poor water pressure supply to the house anyway. After a short time the hw kicks in again and 'pumps' it out at full force. Am i right in assuming the drop in water pressure and subsequent re-firing could be due to the water pressure coming into the house fluctuating due to neighbours using the water? Or is there something else ?
Secondly and more of a problem is that if we turn the CH temperature dial to below half and try to run the boiler, the boiler seems to lockout and the CH light flashes and the
boiler fires, locksout, fires etc etc....Only when we turn the temperature dial to above half will the boiler fire and maintain heating the water. What could be causing this ? It is a bit frustrating (and potentially expensive) that we cannot turn the heating down to a low level as the boiler locks out. Any ideas ? From reading various other posts the PCB is mentioned quite a bit but im unsure.....
Apart from that the boiler seems fine-ish.
Any help or advice would be appreciated
Thanks in advance,
Thanks in advance,
