Worcester Boiler leaking
29 Sep 2007
Lancashire
Hello everyone.
I wonder if anyone can help me with a problem I have with my worcester 24cdi boiler. The problem arose when I repressurised it. Since then there is a constant leak/drip from the filling loop (the part where you insert the filling key into). I've tightened up the grey knob and even checked that the black knob is tightened too. I've noticed that my filling key is a bit battered for some reason. Could this be part of the problem?
Any help would would be greatly appreciated has I really an't afford to call out a plumber.
Thanks.
Gavin.
They key merely acts as a bridge link during filling. It s/be taken out after filling so problem os from either side depends where leak is from.
A well installed system will only need to be topped up every few months!
It sounds as if you have been using yours more often and one of the valves has worn badly.
It will have to be replaced!
Tony
it seems to be from a little hole in the filling loop from the side where the black knob is. ther's a little hole there.
thanks for the help
In fairness to the boiler then I have to say that it has been superb, the last time i pressurised it must be about 9 months ago. I should of said that, Sorry.
if its leaking from the left side of the loop then the non return valve must be clogged/stuck
new probably required.
Just noticed that when the the central heating is running then the leak/drip stops completely.
Expansion closing the NRV. Must be that then. Check again when it cools.
new fill loop section required.
not expensive or particularly hard to replace.
