I have recently had a very expensive bathroom makeover by a local 'reputable' firm. They had recommended and fitted a power shower which proved incompatable with my water system. ~To cut a long story short after discovering this boob on their part I asked them to fit an electric shower instead. There had been an electric shower which worked perfectly well with adequate pressure installed previously.
A Mira Sport 9.8KW has been put in, but the pressure is dire, much worse than our old electric shower (an old 8.5KW). I think this poor performance is because the new shower is fed from a cold feed pipe tapped into the mains near the cold water tank in the loft. It is actually tapped into a pipe which feeds the top up tank for my central heating system which is the last take off after both my own and my downstairs neighbour's cold water tanks.
Our cold water system is all mains fed. The cold tanks are the last take off after the Kitchen through to Bathroom system, first my downstairs neighbour, then mine, then up to the tanks in the loft.
The old electric shower was fed from the cold feed to the bathroom, tapped into the supply to the bath.
I think they have tried a cheap fix instead of breaking into the pipe cavity at back of shower to access the cold feed to the bathroom, without taking into consideration the impact the extra level up into loft ( and length of run!) would have on water pressure.
There is a pipe there as originally they did not realise it was a mains vented system (which would have damaged the power shower originally installed) and put a cold feed pipe in leading from bathroom feed supply (at first floor level). This was not cut back but just capped. I now have two spare pipes in this cavity behind shower a hot and a cold both capped! The pipe in loft (second floor level) they have used to feed the electric shower was the one they originally tapped into my (much too small) cold water tank for the power shower.
Help and advice please from proper instead of mickey mouse plumbers would be greatly appreciated.
