Hello,
I have just installed a new ceramic hob and it worked fine the first day it was installed but on second attempt it seems to have developed a fault... When I turn any of the rings on they start to go red and heat up as they should and then they suddenly click off, then after a short while they will turn themselves on again and do the same thing. I don't think this is a wiring problem as the digital display works consistantly?!
Any help would be much appreciated!
Thank you
Thank you
