Having read the following remark repeatedly when "trawling" through the various threads- "the more you read the more confused you get" I`d like to clarify by asking the following-hopefully giving suffcient information to allow a constructive view.
I`m building a large four bed house with four shower ensuites one also with a bath. (Its not anticipated that more than two maybe three showers would be going in a an hour). Underfloor heating using Uponor. Four towel rails. Downstairs WC. A drying room/airing room has been catered for with a mix of underfloor and a radiator for high level. Obviously dishwasher/washing machine.
I`ve considered heat sources and discounted heat pumps, air conditioning units as air source heat, PV cells and solar. I have two major restrictions firstly the house is in an area of outstanding natural beauty so planning restrictions and secondly my personal dislike for solar on roofs and attached to buildings. My "green credentials " will extend to a pellet boiler but not immediately.
SO with no gas I`ve ended up with oil.
Further information is mains pressure is minimum of 10 bar ( already advised to fit a pressure reducing valve set at about 5 bar).
Want power flow showers so mains pressure.
Heat loss calculated at just over 12kw. - house obviously very well insulated and designed to get as much solar gain as possible.
Questions are
FIRSTLY make/manufacturer and type of oil boiler.
SECONDLY unvented or vented ( I would like to install myself if possible so pressurized system ill-advised and would be illegal)
THIRDLY whose thermal store.
FINALLY as an ageing sceptic I find it difficult to find it possible for the thermal stores to provide an adequate heat source for the number of showers required against the heat loss of the building. It seems logical that I`d have to over size the boiler to provide the flow rate compared to the underfloor heating requirement ( incidently there are 18 heating zones plus towel rails etc as stated).
One final point if important and that is that the underfloor heating is via wireless controls and includes an outdoor weather sensor.
I hope I have made my self clear in the above "book" and as stated given enough info.
Thanks in anticipation. JD
Questions are
