A bit of a difference in angle there but an angled or even straight pan connector should do it. There is some height misalignment so you need to either raise the w/c a little or cut the boss back so it doesn’t distort but make sure you leave enough length for the pan connector to fully engage the inside of the pipe.
cheers for the suggestions, ill chisel out the plaster and see state of play,
i should be able to use a mutikwik extension and connector then
(MKS2 and a MKEA) - didnt even think about knocking the wall about
cut the lead as near the wall as you can, you WILL scrape your knuckles, fit a multikwik "ext A" into the lead and cut to length and fit a multikwik 1/14(angled pan connector) onto pan or get a flexible ext pan connection and it will bend to suit
