AaronUK
Joined: 06 Oct 2009 Posts: 11 Location: Edinburgh, United Kingdom Thanked: 0 times
Posted: Sat Oct 10, 2009 10:47 am Post Subject: Standard kitchen appliance measurements |
When fitting a kitchen what is the standard gap size you leave so the appliances can go in? I've just had a new one fitted but the gap size may be wrong and I am struggling to get a cooker that will fit as most are 60cm.
The gaps they have left are:
Washing machine: 60cm
Cooker: 58cm
Fridge / freezer: 63
Surely I should have 60cm for the cooker? Should I get them back to fix it? Is it standard to leave 60cm when you have the space? |
gregers
Joined: 28 Mar 2008 Posts: 1106 Location: Sussex, United Kingdom Thanked: 29 times
Posted: Sat Oct 10, 2009 3:55 pm Post Subject: |
afaik most appliances are 600mm i leave a gap of 610 where possible so there isnt too much of a struggle to get them in. __________________ reality is for people with no imagination |
| Back to top |
Jasonb
Joined: 20 Aug 2004 Posts: 2001 Location: Surrey, United Kingdom Thanked: 6 times
Posted: Sat Oct 10, 2009 4:16 pm Post Subject: |
Standard opening for freestanding appliances is 600mm as most are about 595mm wide this gives a bit of play.
For integrated you would allow 564 which is a 600mm nominal carcase less twice the 18mm board width.
Jason |
| Back to top |
AaronUK
Posted: Sat Oct 10, 2009 4:25 pm Post Subject: |
Thanks for the replys.
So do you think that the kitchen fitters have done it wrong and I am within my rights to get them back to fix it? |
gregers
Posted: Sat Oct 10, 2009 6:42 pm Post Subject: |
well if you cant get your appliances in then i would get them back to sort out the problem,they shouldve made sure. __________________ reality is for people with no imagination |
