| Author |
Message |
hillmarket
Joined: 26 Aug 2010 Posts: 13 Location: Sussex, United Kingdom
Posted: Wed Oct 27, 2010 8:52 am |
Can someone tell me the proper name for what I call a door stop- no not the fire extinguisher or old iron you put at the bottom of the door to stop it closing!- but that long piece of wood planted on the door liner to ensure the door closes correctly.Also are you able to buy them at a particular width-I'd like some say 85mm in width by 12-14mm thick & tapering down to about 1-2mm at the edge of the door frame/liner. |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
keveljay
Joined: 26 Aug 2010 Posts: 81 Location: Denbighshire, United Kingdom Thanked: 8 times
| Back to top |
hillmarket
Posted: Wed Oct 27, 2010 3:01 pm |
Helo KevelJay,Thanks for your reply-it's those three pieces of wood,two down the middle or perhaps as in my case 35m in from the edge? of the door liner (& one across the top) which stop the door as you pull or push it to close it.Your explanation is probably right given my rather vague enquiry.
Rgds,
H'market |
| Back to top |
^woody^
Joined: 03 Sep 2006 Posts: 12411 Location: Birmingham, United Kingdom Thanked: 1160 times
Posted: Wed Oct 27, 2010 6:33 pm |
Funnily enough, they are called door stops. |
| Back to top |
hillmarket
Posted: Thu Oct 28, 2010 6:29 pm |
Hello Woody,I thought so too but just try &'Goggle'- Door Stop- and see what you get;nothing but little pigs,frogs & sweet dolls and all keeping doors open but nothing to do with keeping them properly closed! |
| Back to top |
crank39
Joined: 01 Dec 2009 Posts: 2012 Location: Derbyshire, United Kingdom Thanked: 261 times
Posted: Thu Oct 28, 2010 7:32 pm |
Way back when i were a lad these were called clapping strips! |
| Back to top |
JohnD
Joined: 15 Nov 2005 Posts: 34463 Location: Hampshire, United Kingdom Thanked: 1096 times
Posted: Thu Oct 28, 2010 7:53 pm |
| hillmarket wrote: | | Hello Woody,I thought so too but just try &'Goggle'- Door Stop- and see what you get;nothing but little pigs,frogs & sweet dolls and all keeping doors open but nothing to do with keeping them properly closed! |
ah, that's the problem. If you want to buy some, you don't google "door stops" you google "pieces of wood" |
| Back to top |
hillmarket
Posted: Fri Oct 29, 2010 11:24 am |
Hello again Wooy,Never would have thought of it in a million years!Thanks very much for both pointing this out and for taking the trouble in responding to my question.
Rgds,
H'Market |
| Back to top |
JohnD
| Back to top |
keveljay
Posted: Sat Oct 30, 2010 7:01 pm |
Hillmarket. Defo always called these a loose rebate stop, although this could be a colloquialism  . Essentially, two types of door casing are available - 1: Inbuilt rebate to hang the door into 2: Flat casing with loose rebate stops that you can position anywhere witin the casing reveal. |
| Back to top |
chappers
Joined: 27 Aug 2004 Posts: 1202 Location: United Kingdom Thanked: 30 times
Posted: Sun Oct 31, 2010 11:44 am |
If you don't have the tools yourself , you will need to go to a timber merchants and get them to machine up a couple of lengths for you or modify some chamfered skirting.
As you want something profiled you will have to scribe or mitre the joints in the corners |
| Back to top |
