DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     About CookiesCookies     SearchSearch     LoginLogin
Patching up old wood lath and plaster
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering
Search this topic :: View previous topic :: View next topic
Author Message
bizron
from United Kingdom
PostPosted: Tue Nov 30, 2010 2:49 pm Reply with quote
I need to patch up parts of old wood lath and plaster where the wood is exposed, what should I use? Also there are quite a few areas where the render is loose and no longer attached to the lath at all. Of course one option would be to remove the whole lot and whack up wallboard but that would be very dusty and involve emptying the bedroom of its furniture, is there a less drastic way of tackling the problem? Cheers icon_cool.gif
Back to top
 Alert Moderators
If you do not want to see this advert, click here to login or if you are new click here to join free.
Diyisfun
from United Kingdom
Thanked: 225 times
PostPosted: Tue Nov 30, 2010 3:46 pm Reply with quote
I suppose it depends on the area, I had small patches, I just put plaster on it. Been there for a few years now.
Back to top
 Alert Moderators
roughcaster
from United Kingdom
Thanked: 545 times
PostPosted: Tue Nov 30, 2010 4:37 pm Reply with quote
Cut away plaster a few inches away from the loose areas,
Clean it down with a brush and water, plus rake out between the laths.
PVA over the whole area, especially the existing edges.
Fill it out to half thickness,
Scratch it,, let it set,
Bring it out flush ready to finish with multi.
I "always" skim the whole wall/s after patching the loose areas.
Back to top
 Alert Moderators
danielrobson
from United Kingdom
Thanked: 4 times
PostPosted: Tue Nov 30, 2010 5:13 pm Reply with quote
roughcaster on your filling coat what did you use? bonding?
Back to top
 Alert Moderators
roughcaster
from United Kingdom
Thanked: 545 times
PostPosted: Tue Nov 30, 2010 6:00 pm Reply with quote
Yep,,, bonding coat Dan.
Back to top
The following user says thank you to roughcaster for this useful post:
bizron (30 Nov 2010)
 Alert Moderators
bizron
from United Kingdom
PostPosted: Tue Nov 30, 2010 8:58 pm Reply with quote
Roughcaster thanks for your detailed response but after what you said I think that in reality I'm going to have to remove all of the old plaster back to the lath because all of it is loose. Then I guess wallboard is the quickest and easiest option? but if I wanted to give it a scratch coat would I use bonding? Cheers
Back to top
 Alert Moderators
roughcaster
from United Kingdom
Thanked: 545 times
PostPosted: Tue Nov 30, 2010 10:14 pm Reply with quote
If it's all loose Biz, then you're right, it's better to remove the old plaster. You might be able to leave the old wooden lath on though, and board on top of that. If you do it that way, give the lath a good clean off, and make sure all the remnants of plaster are removed, so that the wall board lays flat onto the lath. Fix it on with plenty of 35mm drywall screws.
I always use bonding coat to plaster back onto wooden lath, whether it's a patch or a whole wall/ceiling. I reinforce "across" the lath between the backing coats too, with 3" hessian scrim..
Back to top
bizron (1 Dec 2010)
 Alert Moderators
bizron
from United Kingdom
PostPosted: Wed Dec 01, 2010 12:38 pm Reply with quote
Back to top
 Alert Moderators
spc
from United Kingdom
Thanked: 9 times
PostPosted: Sat Apr 02, 2011 10:48 pm Reply with quote
hmmmmmmm why gypsum a nicely lathed wall?
Back to top
 Alert Moderators
plstering
from United Kingdom
Thanked: 34 times
PostPosted: Sat Apr 02, 2011 11:11 pm Reply with quote
iv got 9 bags of bond here if you want them m8
Back to top
 Alert Moderators
roy c
from United Kingdom
Thanked: 331 times
PostPosted: Sat Apr 02, 2011 11:23 pm Reply with quote
Back to top
 Alert Moderators
plstering
from United Kingdom
Thanked: 34 times
PostPosted: Sat Apr 02, 2011 11:27 pm Reply with quote
Back to top
 Alert Moderators
spc
from United Kingdom
Thanked: 9 times
PostPosted: Sat Apr 02, 2011 11:42 pm Reply with quote
Back to top
 Alert Moderators
jrplastering
from United Kingdom
Thanked: 75 times
PostPosted: Sun Apr 03, 2011 9:58 am Reply with quote
did no one else notice roughcasters magic floating knife in pic 1......i want one
Back to top
 Alert Moderators
spc
from United Kingdom
Thanked: 9 times
PostPosted: Sun Apr 03, 2011 10:57 am Reply with quote
its like micky mouse in fantasia, if only he could apply the same knife trick to bringing muck up the stairs from the mixer and on to the board icon_lol.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
Patching lath and plaster 2 80 Thu Dec 19, 2013 11:32 am
rotten wood behind plaster and render 2 380 Tue Jan 13, 2009 10:33 am
plaster on wood 2 600 Sun Jul 29, 2007 10:53 pm
Skimming plaster over small wood areas 2 140 Tue May 05, 2015 12:36 pm
Plaster crumbling around flue on wood burning stove 5 160 Fri Jan 09, 2015 9:34 pm
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
Network | Advertising | Newsletter
DIY | DIY How To | @home | DIY Wiki | DIY Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
