A friend of mine used it for joining copper and endfeed feetings on a piece of artistic furniture and it bonds well and looks very neat, but theres NO way id use it for plumbing/heating.
Have used it to give it a go, and decided it has less pros and more cons. It produces a very neat-looking joint and would be good in places where heat cannot be used, however if you don't put enough on or don't get a good joint and it leaks, it's quite a mission to dismantle it all again - with solder you can often just reheat and run a bit more in, with this you have to cut out and start adding in more fittings to repair. Also, there's very little repositioning time, so if you're in a tight spot you can find it's going off before you've got your pipework exactly where you want it. I certainly wouldn't use it over solder in most situations
