Hello,
Hope everyone is in good health!
The house I live in is around a hundred years old. Last year I replaced all floor boards and some joists in the front room, learnt a lot from the experience. Now, I am doing the other front room, this is separated by a stair case and this room has a bay window. All floor boards have been lifted, there is some rot at the end of some joists. The two little joists in front of the bay window are embedded in the brick of the bay window, the ends are rotten.
1. Do i replace the little joists like for like? They are 5cm by 7cm. I want to avoid removing bricks.
2. There is some sort of abomination that the two little joists rest on, would you suggest building a brick pier of some sort?
3. There are some loose bricks in the bay window, some large gaps and a line of bricks that have holes in them, liquid dpc? Do I point them and then use a 5:1:1 mixture of SLC? How would you apply this? Do you dampen the wall first? What thickness?
4. The larger joists that have a bit of rot, could I cut a bit off and then just slide the joist along as there is a bit off over hang at the other end
5. The air vents are of the iron type and have quite large holes, I have had mice and slugs, what mesh would you recommend and how best to attach to the vents.
I was last on here last year and posted a pic of a clay pipe sticking out of the side of the wall under the joists in the other front room, this clay pipe is a way for air to be circulated and it passes under the cellar stairs into the room that I am working on now. Hope I haven't bored you.
View media item 81372
