I've recently moved house and noticed that when the heating was on the radiators were only hot at the bottom. I vented the air out of each radiator and they are all warm except for one and I think this is due to there not being enough pressure in the system to fill the radiator fully.
I have a SIME Super 102 De Luxe wall mounted fan assisted combination gas boiler. The pressure on the boiler is now down to 0.1 and I can't work out how to top up the CH water system.
I've opened the front panel but can't work it out. Do I need to connect a pipe on to somewhere? In the manual it talks about fitting a temporary hose but I have no idea where this should be fitted to. I'm hoping someone will be able to help and just tell me there's a valve somewhere that you open and it will balance the pressure.
If someone could get back to me that would be great.
Cheers
Mark.
Cheers
Mark.
