| Author |
Message |
learner123
Joined: 06 Mar 2007 Posts: 108 Location: Essex, United Kingdom
Posted: Mon May 14, 2007 1:36 pm |
Hi all,
Please can someone tell me what contactor this is as i need to get a replacement,
Have been told they don't make these any more so what could i use as a replacement,
Any help would be great,
Thanks in advance.
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
JohnD
Joined: 15 Nov 2005 Posts: 34349 Location: Hampshire, United Kingdom Thanked: 1087 times
Posted: Mon May 14, 2007 1:39 pm |
no idea, I can't see it.
Did you intend to attach a picture? |
| Back to top |
learner123
Posted: Mon May 14, 2007 1:46 pm |
lol sorry forgot to add that ha-ha |
| Back to top |
JohnD
Posted: Mon May 14, 2007 2:02 pm |
you need to know what the loading is.
looks to me like 3-phase, no switched neutral.
Does it operate a/c? Motor? Or what?
Is it switched by a timeswitch or thermostat or something?
I don't see any on/off buttons.
Is the old one on a DIN rail or screwed to case?
Once you know its characteristics, should be easy to select a replacement.
Is there a "favourite" make of switchgear or DBs in the installation? Start by looking at the same make (unless rubbish  ) |
| Back to top |
learner123
Posted: Mon May 14, 2007 2:11 pm |
It is run on a three phase system,
Running a air con unit
Thanks |
| Back to top |
JohnD
| Back to top |
learner123
Posted: Mon May 14, 2007 3:18 pm |
Sorry Johny D
I couldn't answer your questions as i don't have the answers.
I have been sent the picture and asked if i could get a replacement.
All i know is it is feeding an air con unit in the ceiling of a room
And that it is on a 3 phase supply.
I sent the picture to crabtree and they said it is not one of there's so im stuck
I wasn't being rude as im sure that is what it look liked, sorry.  |
| Back to top |
ColJack
Joined: 16 Feb 2007 Posts: 11770 Location: West Midlands, United Kingdom Thanked: 408 times
Posted: Mon May 14, 2007 3:21 pm |
looks like telemecanique ( sp? ) |
| Back to top |
david1805
Joined: 21 Jun 2006 Posts: 84 Location: Cambridgeshire, United Kingdom
Posted: Mon May 14, 2007 3:31 pm |
My money is on it being Klockner Moeller.
Regardless, you need to know the size of the unit being controlled in Kw and the control voltage of the coil.
A contactor from any mainstream manufacturer will do the job, don't forget you also need to buy the auxiliary contacts, as can be seen on the right of your picture. Need to get someone to verify whether they are normally open or normally closed. |
| Back to top |
learner123
Posted: Mon May 14, 2007 3:32 pm |
Thanks coljack
Any chance of any more detail's you can give me?
where can i get one?
Im looking all over the place,  |
| Back to top |
ColJack
Posted: Mon May 14, 2007 3:38 pm |
can't really tell without a clearer photo of it what make it is, ask for some more close ups, and see if you can get a shot of any writing on the sides.... |
| Back to top |
THRIPSTER
Joined: 21 Sep 2006 Posts: 201 Location: United Kingdom
Posted: Mon May 14, 2007 3:41 pm |
Find out what it is switching noting the power consumption and then select a suitable alternative from a range of manufacturers - we cannot advise remotely given the little information you have provided.
If you get stuck, then contact a local, friendly commercial electrician. |
| Back to top |
learner123
Posted: Mon May 14, 2007 3:50 pm |
the only writting i have been sent that is on it is as follows:
TC1,,,,,,,, D6511(or D65II),,,,,,,,TC
21nc or could be 2inc
13NO
Thanks for all posts so far. |
| Back to top |
passerv
Joined: 10 May 2007 Posts: 47 Location: Southampton, United Kingdom
Posted: Mon May 14, 2007 4:05 pm |
| Back to top |
ch427
Joined: 16 Jan 2006 Posts: 2087 Location: Cardiff, United Kingdom Thanked: 166 times
Posted: Mon May 14, 2007 4:17 pm |
somewhere like rs components is your best bet,it looks like you have 1 normally open and 1 normally closed contact but you need to determine coil voltage and load as already mentioned |
| Back to top |
