luton bloke
Joined: 30 Aug 2007 Posts: 5 Location: Luton, United Kingdom Thanked: 0 times
Posted: Thu Aug 30, 2007 10:51 pm Post Subject: power shower help |
hi guys im installing a power shower, i have the cable running from the bathroom into the loft. where is it best to feed the cable into ? and how lol. |
Taylortwocities
Joined: 27 Jul 2006 Posts: 4932 Location: Oxfordshire, United Kingdom Thanked: 63 times
Posted: Thu Aug 30, 2007 10:57 pm Post Subject: |
What sort of shower?
What is the KW rating of the shower?
More info = more help __________________ TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R. |
Spark123
Joined: 02 Jun 2005 Posts: 10887 Location: Cumbria, United Kingdom Thanked: 39 times
Posted: Thu Aug 30, 2007 10:59 pm Post Subject: |
Firstly please can you confirm this is just a pumped shower?
Ideally it should be run from a power circuit such as a ring circuit via a doule poled switched fused connection unit with the correct sized fuse installed. The circuit should also be RCD protected. The circuit needs to be included in the supplementary equipotential bonding arrangements for the bathroom. Please note, this work is notifiable to your local area building control under Part P of the building regs. |
luton bloke
Posted: Thu Aug 30, 2007 11:03 pm Post Subject: power shower help |
hi guys its a triton power shower with just a pump reqiring a 3 amp fuse ? |
Spark123
Posted: Thu Aug 30, 2007 11:06 pm Post Subject: |
Model number? |
