DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
central heating
This topic originated from the How to page called Problems associated with radiators
Click here to return to the page called Problems associated with radiators.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
bazza55
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 02, 2007 12:31 am    Post Subject:
central heating
Reply with quote Thanks
i currently have a vailant combi boiler which has run 10 radiators perfectly for tha last 9 years, i have recently built an extension which has 2 extra radiators. the plumber i used disconnected all the central heating when i first started and a couple of days ago reconnected the central heating i am now getting 10 radiators red hot and 2 cold and the plumber is telling me its the boiler, i have tried knocking all the hot radiators off to try and force the pump to pump to the cold radiators but to no avail.the radiators in question one is the nearest to the boiler the other is one off the new radiators upstairs, i think i am being ripped off by the plumber to the price of a new boiler.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Sep 02, 2007 12:43 am    Post Subject:
so do i.
you havent mentioed bleeding the rads, have you?
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Sun Sep 02, 2007 1:05 pm    Post Subject:
Boiler sounds as if it is running ok if 10 rads heat up icon_rolleyes.gif As breezer says, check for air locks etc and also check that the l/sheilds are fully open and that any trv operating pin has not stuck down closed.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 59 times
PostPosted: Sun Sep 02, 2007 1:29 pm    Post Subject:
If you leave just the new one on and both valves are fully open( remove trv head if its a hot day) and it still does not heat up , it has possibly been teed into just the flow or just the return
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Noise of central heating pump vibrating through my wall! 7 1340 Sun Apr 20, 2008 3:25 pm
Central Heating Boiler vent Pipe 2 340 Mon Apr 21, 2008 11:06 am
running central heating and hot and cold water in concrete f 23 600 Sun Apr 20, 2008 3:07 pm
central heating system/boiler wires? 12 480 Sat Apr 19, 2008 3:07 pm
Central heating Programmer - Fused spur needed question? 4 200 Thu Apr 17, 2008 11:45 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
