Elecrtro Oil Inter B11 Burner, Bentone motor needed asap!
10 Feb 2007
Cumbria
I have got an Heatslave 20/25 OIL boiler needing a new motor, a Bentone (FHP-Motors EB95C35/2 part) . Electro Oil Inter B11 Burner. Worcester boiler.
Who retails online or does and anyone have any useful merchants for oil parts?
I have had a genuine problem with one of those motors on a 18 month old machine recently. I suspect there may be a production problem as motor failures are so rare. How did you conclude the MOTOR is at fault?
Final prognosis was the pump after all! Motor turned once uncoupled from pump.
Found a good stockist in Kendal, not close but same day collection and fitting.
I have same motor on a late 80's Trianco TR028/32 Bolier.
The motor failed at the weekend.
Bought a replacment EOGB MOTOR 90W M0219012 INTER 10 11 12 99 109 which simply 'plugged' in without any hassle.
My question is, under normal running conditions, how hot should the back of the motor become?
It would be helpfull if you stuck to one thread!!
