DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Central Heating programmer/timer upgrade
This topic originated from the How to page called Installing a electrical mounting box
Click here to return to the page called Installing a electrical mounting box.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
tomengo
from United Kingdom
Thanked: 0 times
PostPosted: Wed Sep 05, 2007 11:22 am    Post Subject:
Reply with quote Thanks
Hi all, I am going to attempt to upgrade the programmer for my central heating (old MK1 SUNVIC with analogue clock) to a digital one bought from Trav.Prkns. The old SUNVIC has 19 wires going in and the new IFLO has 7. I will buy a connecting plate to sort this. Can someone please tell me which wires go where? Many Thanks.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
luminaire
from United Kingdom
Thanked: 0 times
PostPosted: Wed Sep 05, 2007 11:31 am    Post Subject:
Will this be of any help to you?
Back to top
 Alert Moderators
tomengo
from United Kingdom
Thanked: 0 times
PostPosted: Wed Sep 05, 2007 12:04 pm    Post Subject:
Hi, thanks for your quick response. Unfortunately, the link you sent me failed and locked up my web browser. I think the honeywell site has been updated and so im no longer able to access that page.
http://content.honeywell.com/uk/homes/systems
Back to top
 Alert Moderators
RICelectric
from United Kingdom
Thanked: 0 times
PostPosted: Wed Sep 05, 2007 12:29 pm    Post Subject:
C Plan
Suitable for new and existing installations with pumped heating and gravity hot water circuits.
C Plan Schematic
C Plan Wiring
The Honeywell items used in the installation of this plan will be:
1 - T6360B1028 Room Thermostat
1 - L641A1039 Cylinder Thermostat
1 - V4043H1106 28mm Zone Valve
*Optionallly
1 - 10 Way junction Box - 42002116-001 or
1 - Wiring Centre - 42005748-001
1 - Programmer - ST6400C1003
S Plan
Suitable for fully pumped installations with two primary circuits, usually one for heating and one for domestic hot water.
S Plan Schematic
S Plan Wiring
2 - V4043H1056 22mm Zone Valve
*Optionallly
1 - 10 Way junction Box -42002116-001 or
S Plan Plus
Similar to the Sundial S Plan but for use with 3 or more primary circuits, generally two heating zones and one for domestic hot water, Heating zones can be controlled by a combination of time controls and thermostats or by programmable thermostats.
S Plan Plus Schematic
S Plan Plus Wiring
This is the tham diagram as for the standard S Plan but with additional heating zones as required.
2 - T6360B1028 Room Thermostat
3 - V4043H1056 22mm Zone Valve
Note: The number of room thermostats and zone valves will be dependent upon the number of heating zones.
*Optionallly
Note: The number of junction boxes and programmers will be dependent upon the number of heating zones.
W Plan
Suitable for fully pumped installations wher it is acceptable to heat only one circuit at a time and normally installed to give priority service to the domestic hot water circuit.
W Plan Schematic
W Plan Wiring
1 - V404C1288 22mm Diverter Valve
*Optionallly
1 - Programmer - ST6200A1009
Y Plan
Similar to the W Plan but with the ability to supply both heating and hot water circuits at the same time, if required.
Y plan Schematic
Y Plan Wiring
1 - V4073A1039 22mm Mid position Valve
*Optionallly
Back to top
 Alert Moderators
tomengo
from United Kingdom
Thanked: 0 times
PostPosted: Wed Sep 05, 2007 2:22 pm    Post Subject:
Hi. thank you for sending the contents of the web page, I used firefox browser & for some reason it didn't like the link, but internet explorer was fine icon_smile.gif
I could use a little more help as to which plan to follow as a few of them seems compatible to me. Im not sure if I have gravity hot water, but I do have a gravity fed cold water tank in the attic.
There are many wires coming from the old SUNVIC, I've tried to identify where they are from to help choose which plan schematic to follow.
http://www.flickr.com/photos/tomengo/1330610346/
Any more tips or suggestions would be gratefully received!
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Wed Sep 05, 2007 4:33 pm    Post Subject:
That is a Y plan in your photo.
There was no need to duplicate post in plumbing section then as you have already had good answers.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
tomengo
from United Kingdom
Thanked: 0 times
PostPosted: Fri Sep 07, 2007 10:38 pm    Post Subject:
hi, today I bought a 10 way junction box. I was getting to grips with the Y plan schematic, (building up confidence) but soon realised that there are a few things that don't add up (in my mind) icon_confused.gif
I noted all the wires on a piece of paper and compared them next to the honeywell Y-plan.
First, the valve at home has 4 wires (brown, grey, orange, blue) where the Y-diagram has 5 wires (?) that makes me unsure as to which wire to screw into which number (1-10)
Second, The cylinder stat also has 4 wires (blue, yellow, white, grn/yell) where the Y diagram shows the cyinder stat with 3 wires (clearly not colour marked) Just 1, 2 & c [?]
My old SUNVIC programmer again: http://www.flickr.com/photos/tomengo/1330610346/
Last, I have a brown wire called 'permanent ' I'm thinking that's the 230v power-in. I have a neutral from the 230v too, but no earth...is that a problem? icon_eek.gif
Sorry to be such a noob. Im very grateful for any help.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Central Heating timer/programmer upgrade 5 4220 Wed Sep 05, 2007 11:26 am
Upgrade Central Heating Timer 3 400 Wed Dec 17, 2008 12:58 pm
Central heating upgrade - flush or not to flush 13 4280 Sat Aug 25, 2007 10:55 am
Central Heating Upgrade 9 780 Mon Jun 18, 2007 9:22 am
Complete central heating system upgrade. 32 2280 Fri May 23, 2008 9:38 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
