DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Earthing Steel Dimmer Switches
This topic originated from the How to page called Replacing a one-way light switch with a dimmer switch
Click here to return to the page called Replacing a one-way light switch with a dimmer switch.
  View previous topic :: View next topic
Author Message
roger-bernhardt
from United Kingdom
Thanked: 0 times
PostPosted: Wed Sep 05, 2007 1:10 pm    Post Subject:
Reply with quote Thanks
We had an electrician install a few steel 2G Dimmer Switches. There was a fault with one so I opened it up to discover that the earth wire was not connected to the face plate/switch. I opened up the others and none of them had the earth connected. Is this dangerous? I have now earth wired both the mount box and faceplate independently. Is this ok or do they have to be earth wired to each other?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Steve
from United Kingdom
Thanked: 23 times
PostPosted: Wed Sep 05, 2007 1:23 pm    Post Subject:
Just the face plate is sufficient. If you've done both, this is fine. If you have two cables with two earth wires, they must be in the same terminal.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Wed Sep 05, 2007 1:33 pm    Post Subject:
It doesn't matter if you put the earth wires into the back box or the face plate; BUT you must link the earth terminal of the box and the plate together with a piece of G&Y sheathed, otherwise you are relying on the integrity of the fixing screws, which are sometimes removed, loose or suffer corrosion in the box. Same with sockets. Lots of people keep a pocketful of G&Y in 6" lengths for this very purpose (I sell them at 50p each if you want some icon_lol.gif
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Earthing & Steel Conduit 2 460 Mon Mar 07, 2005 12:57 am
Earthing a steel bath 18 2340 Thu Mar 04, 2004 5:08 pm
earthing a stainless steel sink with plastic pipework 7 500 Fri Feb 22, 2008 6:26 pm
Earthing a stainless steel splashback in a kitchen 23 1440 Wed Apr 21, 2004 12:02 pm
Replacing plastic switches with stainless steel dimmers 5 400 Tue Jun 27, 2006 10:04 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
