Joined: 07 Sep 2007 Posts: 30 Location: Leeds, United Kingdom Thanked: 0 times
Posted: Fri Sep 07, 2007 10:16 am Post Subject:
Moving a light switch
I need to move a light switch about 6 to 8 inches to one side.What\\\'s the best way to do this a) if there is enough slack cable and b) if the cable needs extending.
Joined: 15 Apr 2005 Posts: 12845 Location: Yorkshire, United Kingdom Thanked: 21 times
Posted: Fri Sep 07, 2007 10:46 am Post Subject:
. . . replace the cable. Why do you want to move the switch?
It would be acceptable to fit a blanking plate where the existing switch is, and make the joint to extend the cable here. And the cable would still be in safe zones then. Safe zones run directly horizontal and vertical from any accessory.
Posted: Fri Sep 07, 2007 11:07 am Post Subject:
My wife wants to put up an 'arch' to make our dining area off the lounge a more definite space and the switch is in the way.If I come off horizontally from the existing switch is it OK to wallpaper over the existing 'hole' and how should I block it off?
Also if the cable isn't long enough is it permissible to use a joint block in the existing switch space?
Thanks again
Joined: 17 Nov 2006 Posts: 1680 Location: West Glamorgan, United Kingdom Thanked: 0 times
Posted: Fri Sep 07, 2007 1:12 pm Post Subject:
teddyman5 wrote:
Can I blank it off in such a way as to make it flush with the existing wall so it can be papered over?
No, as Steve mentioned, the safe zones are horizontally and vertically from any accessory. If you can't see the accessory the safe zones do not exist and cables can not be run there without additional mechanical protection.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
