I know this must be a common problem but I searched the forum and could not find someone with the same issues!
I have recently moved into a new house and the hot water has not worked since moving in, it will only work if I put the immersion heater on, the CH works fine.
I had a little investigation today and it seems the boiler is not switching on when I select hot water, it only on switches on if I select heating.
Does this pretty much point to a faulty heating control/programmer unit as it seems it is not telling the boiler to give me hot water?
My boiler is an: Ideal E type RS ballanced flue gas boiler.
The programmer is the old Landis & GYR dial type.
Thanks in advance for any help!
