Baxi Combi Instant HE fault
15 Sep 2007
Wiltshire
I have a Baxi Combi Instant HE boiler and this morning I cannot get any hot water.
A light is flashing which indicates that there is an issue with the Fan or Flue.
Could this be an expensive problem to be fixed? Would someone recommend getting a plumber to fix it or should I get it fixed using British Gas HomeCare options.
Any help gratefully received,
Cheers Joe.
It could also be the PCB at fault.
Certainly you will need a competent engineer and in parts of Wiltshire they are in short supply.
It might be something quite minor in which case a local engineer could repair it for less than £100. If you engage Baxi or BG then its going to be more like £200 but will be capped at that figure.
Its a bit of a gamble for you!
Tony
Thanks Tony,
I have not hot water, I can call british gas out for £150 inclusive and guaranteed for 12 months - which sounds pretty good to me after what you have said,
Thanks for advice,
Cheers Joe.
