ACT
Joined: 16 Sep 2007 Posts: 1 Location: Selkirkshire, United Kingdom Thanked: 0 times
Posted: Sun Sep 16, 2007 11:19 am Post Subject: Wiring a 2 gang dimmer switch |
I am replacing a normal two gang light switch with a dimmer switch.On each dimmer switch are three terminals, L1, L2 and a wavy line.There ate two cables coming to the present light switch as follows
Cable 1 Earth wire connected to the wall plate, the red wire connected to the switch and the black wire hanging loose
Cable 2 Red wire connected , the black wire with a red tube over and the earth wire all connected to the switch.
Can you help?  |
jj4091
Joined: 01 Dec 2006 Posts: 1794 Location: Cumbria, United Kingdom Thanked: 8 times
Posted: Mon Sep 17, 2007 7:56 am Post Subject: |
Which terminals on the switchs are the various wires connected to? |
