DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Baxi Solo Overheating
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
simms5280
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 18, 2007 8:56 am    Post Subject:
Reply with quote Thanks
I have a Baxi Solo Bolier.
When i call for hot water the boiler fires up for around 3 minutes (noises from the boiler get louder during this 3 minutes)then the overheat switch goes and i have to leave it a good 5 minutes before it will reset.
When i call for central heating the boiler does not fire up at all. So i dont know whats wrong with that.
I have had all the electrics checked and they are fine, the pump is also new aswell. Could it be the diverter? Valves ?
Im really lost now
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Tue Sep 18, 2007 9:01 am    Post Subject:
Sounds like lack of circulation. I would firstly check there is 230V at the pump when the hot water is on. The boiler pcb supply's this so if there isn't it could be a pcb failure.
The not coming on on heating sounds like a zone valve fault. If you have 2 zone valves then check for 230V at the orange wire from the heating valve. If a 3 port valve then do the same.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Baxi solo overheating 4 1080 Tue May 17, 2005 7:20 pm
baxi solo 3 overheating 11 2940 Sat May 12, 2007 2:43 pm
Baxi Solo 2 Overheating Problems? 17 3480 Wed Dec 20, 2006 6:43 am
Baxi Solo 3 30/80 overheating 2 2300 Sun Apr 17, 2005 3:53 pm
Baxi Solo boiler overheating? 6 340 Fri Jan 30, 2009 6:43 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
