DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
wiring a cupboard light
This topic originated from the How to page called Adding a new light and switch
Click here to return to the page called Adding a new light and switch.
  View previous topic :: View next topic
Author Message
fraserrobyn
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 18, 2007 1:01 pm    Post Subject:
Reply with quote Thanks
i am wiring a cupboard light from existing switch in lobby ,the switch has 3 cables and an earth ,does my new light have to have as many cables. thanks : icon_confused.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Tue Sep 18, 2007 1:04 pm    Post Subject:
You will not be able to wire your cupboard light from the switch. There is no neutral there.
You will need to pick up live, neutral and earth from the lighting circuit - usually this can be found at a ceiling light.
This is not what you want to hear.
If lifting floorboards and chiseling out your walls isnt part of your plan then the next best option is to add a 3A fused spur to a nearby socket and power your lights from there.
__________________
TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R.
Back to top
 Alert Moderators
fraserrobyn
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 20, 2007 9:17 am    Post Subject:
cupboard light
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Thu Sep 20, 2007 9:25 am    Post Subject:
Re: cupboard light
fraserrobyn wrote:
No. Why would you connect a NEUTRAL to a switch? A switch simply makes or breaks a contact between 2 wires. If the 2 wires are live and neutral, what happens when you make the contact? BANG!
I suggest you get an electrician to do this work for you. The phrase "does my new light have to have as many cables" does not inspire confidence in your ability to do this work.
If you do wish to do this work yourself, please study at great length the diagrams in our wiki, in particular:
http://www.diynot.com/wiki/electrics:lighting:single_way_lighting
http://www.diynot.com/wiki/electrics:lighting:lighting_circuit_layouts
Before you do any work on your lighting circuit, please make certain you understand what exactly you are doing, and NOTE WHAT GOES WHERE. A good 20% of posts on here are from people who didnt.
Back to top
 Alert Moderators
aptsys
from United Kingdom
Thanked: 2 times
PostPosted: Thu Sep 20, 2007 10:03 am    Post Subject:
There may be a neutral in the switch if the loop exists in the switch rather than at the ceiling rose. It sounds like this may be the case if you really meant there were three cables at the switch rather than three wires
Back to top
 Alert Moderators
fraserrobyn
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 20, 2007 10:14 am    Post Subject:
cupboard light
hi cant send picture at this time but i have 4 wires coming into switch blue onto L2 yellow onto L1and red onto the top with the earth onto back plate thanks icon_confused.gif
Back to top
 Alert Moderators
aptsys
from United Kingdom
Thanked: 2 times
PostPosted: Thu Sep 20, 2007 10:15 am    Post Subject:
In that case, there is no neutral available at the switch.
Back to top
 Alert Moderators
fraserrobyn
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 20, 2007 10:24 am    Post Subject:
cupboard light
thanks everyone icon_redface.gif now 2 plan b can i take the light from a socket nearby with a switch inline with alight on one end and fused plug on other icon_wink.gif
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Wiring cupboard light from ring main 2 300 Tue Aug 26, 2008 7:20 am
Wiring kitchen under cupboard lighting 8 1000 Sat Apr 08, 2006 1:39 pm
airing cupboard wiring query 3 160 Wed Sep 09, 2009 2:33 pm
Location of light switches inside wall cupboard 2 460 Fri Oct 13, 2006 2:34 pm
Airing Cupboard Automatic Light Switch 9 500 Sat Apr 25, 2009 2:26 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
